12/11/2017 6:36 PM | |
Joined: 7/20/2006 Last visit: 10/15/2024 Posts: 128 Rating: (8) |
Hi, Is it possible to compere each other two different recipes? I try to follow that procedure: https://support.industry.siemens.com/cs/ww/en/view/43909546 But I can not find BFAPICMX_VBSampleX.exe application on clientPC(on server as well). I try to export recipe from batch control center level as XML files but then they are not readable (when i open it notepad++). Any ideas? My batch is 8.1. regards Edek |
12/11/2017 7:03 PM | |
Joined: 3/14/2008 Last visit: 10/15/2024 Posts: 2111 Rating: (942)
Hi edek, Please follow the following FAQ: Sample Application for SIMATIC BATCH COM API I think this is what you are looking for! |
Last edited by: Oreca at: 12/12/2017 7:53:58 AMadded link for the sample application Last edited by: Jen_Moderator at: 12/12/2017 10:01:43 AMInserted right links. If I could help you, you can use the RATE button. Thank you. |
12/12/2017 7:45 AM | |
Hi edek, Ow, I saw you already posted the link. The sample application can be found here: Sample Application Simatic Batch |
Last edited by: Jen_Moderator at: 12/12/2017 10:02:33 AMInserted righ link. If I could help you, you can use the RATE button. Thank you. |
