10/5/2024 5:10 PM | |
Joined: 3/14/2008 Last visit: 10/5/2024 Posts: 2107 Rating: (940)
Hi, It's a problem with the driver block (Pcs7AnIn). If it worked before, I quess you accidently imported a block from an old version or so. Maybe you can compare the block version from the Blocks folder with the AP library and see if any differences are found. |
