8/26/2022 10:01 PM | |
Joined: 10/18/2007 Last visit: 6/10/2024 Posts: 65 Rating: (3) |
Hello all, I am experiencing a similar issue. I recently had to install a HotFix1 patch for Modbus Red CP V3.0 library. The install process of doing a Chart Block Types Update from the library didn't work, and Siemens advised to instead use Block Type New Version import for the FB908/FB909 blocks. This seemed to work well, and compiled initially without error. Eventually I had to place a new Job_List_SCL block when writing some logic, and at that point I received this exact compile error. Does anyone know what could be causing this, or have a workaround? In my case everything works perfectly fine with the V3.0 library pre-HF1, but as soon as HF1 is installed it causes these compile errors. Thanks for any help! ------------------------------------------------------------------------------------------ |
Last edited by: The Helping Hand at: 08/31/2022 13:41:21New subject after splitting |
