4/15/2013 4:22 PM | |
Joined: 9/27/2006 Last visit: 3/22/2023 Posts: 11993 Rating:
Hello marc; Our friend Pegaia is too modest. He is one of the major references for help on the S7-1200 CPUs on the forum, and he proposed earlier a sample program that could give you pointers for your project: Sample Program: S7-1200 High Speed Counter (HSC) Once you have obtained your average value in the PLC, you only have to display it on your HMI, using an output field. Hope this helps, Daniel Chartier |
4/15/2013 8:18 PM | |
Posts: 5 Rating:
Hello Daniel, Thank you for your answer. But this anwswer don't help me. Because i dont know the tia portal. I am a teacher, and in my school we always worked with pl7-pro (...). And today j want to work with siemens, but learn alone is difficult! I join you a work paper, this paper is in french sorry. Canyou help me? Thank you for your help Marc Attachmentprog.zip (318 Downloads) |
4/15/2013 10:47 PM | |
Hello Marc; I can appreciate that moving from older Modicon PLCs to the newest platform for Siemens CPUs can be a bit daunting, but there are tools that you can locate to help you out. First, know that Siemens provides a lot of information in manuals on its site, and in various languages. French is very well covered. For example: Simatic Step 7 v.10.5 SP2 en français. Look at chapter 6.4.6 (p. 264 et suiv.) for a description of available high-speed counters and their configuration. You can then follow Pegaias sample project with more ease. If the version of Tia Portal you have is different, here is a link to a variety of manuals covering Tia Portal, select the manual you need, and in the download page, select French from the list of available languages, at the top of the page. This should make your understanding of the Portal much easier. Available manuals for TIA Portal One more suggestion: here are links to video tutorialson TIA Portalfrom the web, they should give you a good start with the software:Video tutorial to get started with STEP 7 (TIA Portal) - Siemens Siemens TIA Portal V11 Tutorials - YouTube Hope this helps, Daniel Chartier |
