3/21/2023 5:31 AM | |
Joined: 1/21/2013 Last visit: 7/11/2024 Posts: 2971 Rating:
Hi, Since you are already testing with PRONETA, a screenshot of the graphical view for both the working and the failing configuration might be helpful. Also, a screenshot of the topology view of TIA Portal while connected to the PLC in the fault case will show us more details. Which ET 200 are you using? Please also provide the details I requested in my first post, as at this point I do not understand what you are doing. Kind regards |
3/21/2023 8:43 AM | |
Hi, Have you already tried to check the configuration state of the port on the SCALANCE XB213-3? You can do this with the Web Based Management (see chapter 6.4.14). Kind regards |
