10/22/2013 9:20 AM | |
Posts: 107 Rating:
Can i Do that? Use the hmi like a pass through |
10/22/2013 10:55 AM | |
Joined: 4/24/2006 Last visit: 7/12/2024 Posts: 8711 Rating:
Hello carloschanc, You want to log data on ethernet. The TP700 Comfort can log data on ethernet. how do you integrate an HMI operator panel into a local network? Best regards, Wizard |
10/22/2013 11:53 AM | |
Posts: 107 Rating:
Hello wizard. so, i cant do a database with that hmi? with a opc or something? i only can write datas by ethernet to pc Best regards |
10/22/2013 12:31 PM | |
Hello carloschanc, I've found the following links: how can you output tags from an SQL database via a trend archive? how do you log tags in an SQL database and read them out again with WinCC flexible? Which SQL database can you use for archiving tags and messages with WinCC flexible Runtime on an Industrial PC? how do you access an SQL database in WinCC flexible via a script? It's all about WinCC flexible Runtime. Not for HMI panels. Perhaps it might help you. Best regards, Wizard |
10/23/2013 9:40 AM | |
Posts: 107 Rating:
i know that with a scaada i can log mi files into a SQL database with adodb conection. With a hmi can i do that too? |
