2/18/2024 3:01 AM | |
Joined: 4/28/2015 Last visit: 6/19/2024 Posts: 9 Rating: (0) |
what is u ncu version? before version sw4.7 ,root password can get . |
2/20/2024 7:01 AM | |
Joined: 4/28/2015 Last visit: 7/8/2024 Posts: 355 Rating: (38) |
Hi As others have said you can always close / deactivate the ssh port, on newer software versions this can be carried out locally on the HMI but if not then you would need to edit the basesys.ini configuration file on the system CF card. Path = /user/system/etc/basesys.ini In addition there are a number of security guides issued now which maybe worth sharing with your security team so that they have a full picture of the options available: https://support.industry.siemens.com/cs/us/en/view/109802750 https://support.industry.siemens.com/cs/us/en/view/109481158 Hope this helps Luke |
