2/7/2006 10:47 AM | |
Posts: 3149 Rating:
Hi Ranr_mids, at the moment it´s not too clear, whether you want A) or B) A) no one can login => not any operation can be done with WinCC??? B) ONLY a predefined WinCC standard-user should be automatically logged in at WinCC/computer start B) http://support.automation.siemens.com/WW/view/en/19141675 http://support.automation.siemens.com/WW/view/en/1947167 http://support.automation.siemens.com/WW/view/en/16737355 http://support.automation.siemens.com/WW/view/de/15390777 Good luck, Nemo |
2/7/2006 11:34 AM | |
Posts: 3149 Rating:
what about using WinCC WebNavigator???? |
2/14/2006 12:36 PM | |
Posts: 3149 Rating:
, and disable the normal Login function? Hi ranr_mids, datamonitor+webnavigator are options => must be bought separately. http://support.automation.siemens.com/WW/view/en/16737355 http://support.automation.siemens.com/WW/view/en/19141675 regards nemo |
2/28/2006 9:53 AM | |
Posts: 3149 Rating:
Hi ranr_mids, if you are giving your WinCC users just "monitoring" rights, they can just have a look :-) nemo |
