6/10/2011 7:31 AM | |
Joined: 3/21/2006 Last visit: 4/25/2024 Posts: 10228 Rating:
Hello, Perhaps in message's Help Text you could find the reasons for that. Take a look at What should you watch out for when adding components or changing their parameters using CiR (Configuration in Run)? Which DP slaves can be added to and removed from a PROFIBUS DP master system using the CiR function (Configuration in RUN) and which configuration changes are permissible? Best regards, Hristo Mihalev |
2 thankful Users |
