5/22/2024 5:47 AM | |
Joined: 11/30/2018 Last visit: 6/19/2024 Posts: 33 Rating:
Good day, TIA Portal v19, unified update 2, CPU 1515F-2 PN How do I enable HMI tag "cyclic continious" method? I cannot find the option mentioned in the manual: Configuring cyclic operation - SIMATIC HMI WinCC Unified V19 - ID: 109828368 - Industry Support Siemens The problem is that switch element won't update until I refresh the picture if I click on it and switch state bit does not change. Thank you! |
