7/9/2009 8:16 PM | |
Joined: 3/21/2006 Last visit: 12/2/2024 Posts: 10229 Rating: (1181) |
Hello, Basically you can start with SIMATIC Process Control System PCS 7 Compendium Part A - Configuration Guidelines Of course if we speak about PCS7... Regards, Hristo Mihalev |
7/10/2009 9:08 AM | |
Hello again, So look at following example Connecting a SITRANS P (DS series) to PCS7 via a PROFIBUS PA - communication The logic is the same for other type of instruments. Hope this will helps. Best regards, Hristo Mihalev |
7/10/2009 9:18 AM | |
Posts: 272 Rating: (4) |
Hi, i think you have to configure it in the hardware config ...and the resp. addresess will be automatically given/... |
