2/18/2016 5:10 AM | |
Joined: 4/20/2015 Last visit: 5/7/2024 Posts: 12 Rating:
hello, I want to know can I connect 16 power module of current carrying capacity 10A and input current for it from no load voltage is 4mA to 20Amp. sitop. ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 2/18/2016 12:44:30 PMNew subject after splitting |
2/22/2016 2:04 PM | |
hi Rakesh, I don´t know why it should not be "compatible". I is also not really clear how you want to use the Power-Modules. Maybe this manual helps you to understand how the Power-Management in ET200s works. Have a look in chapter 3.4 SIMATIC Distributed I/O System ET 200SFor further information of the PM, search for the technical data or the manual of the PM. hope this helps, regards, |
FCK WAR! |
2/25/2016 1:41 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4770 Rating:
New question published by Rakesh Mangrulkar is split to a separate thread with the subject SITOP is going to shutdown. Best regards |
