4/24/2008 1:00 AM | |
Posts: 2661 Rating:
You need the properdevice data files for this. Simatic PDM supports all devices listed in the device catalog. Did you import the device data from the separate CD (in the PCS7 software pack)? You can also download the device data. Example: http://support.automation.siemens.com/WW/view/en/22155058 Your device needs to figure in the device catalog, else you'll have the problem you are facing. It might be a good idea to approach Siemens tech support since they have the latest device lists (newer devices that do not appear in the CD or available for download) Regards |
