3/30/2017 8:44 AM | |
Posts: 6 Rating: (0) |
Hi I am trying to connect IOT2000 device ( picobox) with s7-1500 plc simulator. I am getting repeated issue of "Error connecting to PLC: Error: read ECONNRESET". Can somebody body guide me to resolve this issue. Regards Suyash ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 3/30/2017 9:52:05 AMNew subject after splitting |
3/30/2017 10:39 AM | |
Joined: 4/28/2015 Last visit: 8/26/2024 Posts: 3345 Rating: (379)
Hi, I assume that you are using s7 node-red node right? Are you able to ping the simulated PLC from your IOT? In this post the same problem occured. JDarius had a solution:
Best regards! |
Not working for IOT2050 support anymore from March 1st, 2024. |
3/30/2017 11:05 AM | |
Posts: 215 Rating: (6) |
My problem occured while using PLC Sim Advanced. Do you use this software or the TIA version (PLC-Sim Vxx.x)? |
3/30/2017 12:30 PM | |
Hi I am currently using PLCSIM V13 for simulation. Regards Suyash |
3/30/2017 12:40 PM | |
Are you using node red? Or how do you try to access your PLC? What IOT are you using? |
