6/17/2009 8:59 AM | |
Posts: 54 Rating: (0) |
Hi all guy, I am trying to use faceplate in WinCC 6.2 with WinCC Add-on Powerrate 2.0 for power management system. In Powerratemanual said that when you select the object, the "Connect picture block to tag structure" line will visible in Standard tab ofDynamic Wizard, but whenI select object, it is still invisible so I can not connect the faceplate to structuredata load from PLC to WinCC. Pls give me some advises? AttachmentThe page about Dynamics Wizard.pdf (527 Downloads) |
6/17/2009 9:01 AM | |
One more pics for details |
6/18/2009 3:23 AM | |
Greating Sydney, I tried and see that it was running correctly, thanks for your support. Regards, anhtuan_ntc |
