10/23/2020 10:02 PM | |
Posts: 1 Rating:
hi ,I am a amateur pragrammier, i should connect plc s7-1200 to vb.net through opc server but i can not do it , if i don't do it i loss my job , please help me , please ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/26/2020 05:50:52New subject after splitting |
10/26/2020 7:43 AM | |
Joined: 3/19/2020 Last visit: 8/7/2024 Posts: 28 Rating:
Hi, Give details of TIA version you are using? Also send S7 1200 cpu version. Regards, Nilesh |
10/28/2020 1:01 PM | |
Joined: 8/3/2009 Last visit: 8/8/2024 Posts: 13489 Rating:
Hello If the S71200 should be OPC UA Server then you need TIA Portal V16 and latests Firmware. Then you can run the OPC UA Server on S71200. for access with .Net you can use this: https://support.industry.siemens.com/cs/de/en/view/109737901 Bye Murof |
