1/6/2011 5:28 PM | |
Posts: 8 Rating: (0) |
do you have any other ducument ? i try to connect the 2 cpu 313C-2DP aas you tell us but my try is failed please explain to me. this is my project instep 7 http://www.mediafire.com/?41hdp4a95hy711y. thank you very much |
Last edited by: Blue Moderator at: 06.01.2011 19:47splitted from /tf/WW/de/Posts/27465#top and renamed |
1/6/2011 5:46 PM | |
1/6/2011 8:44 PM | |
Joined: 9/27/2006 Last visit: 7/14/2024 Posts: 12268 Rating: (2675) |
Hello Thanhnguyen; I am sorry, but I am unable to open the file you posted. The pdf prepared by Eastern was very detailed, I wonder why you could not make it work in your application. In the meantime, here isa document prepared by Siemens on the same subject. Try to examine it step-by-step, especially the data exchange addresses, and compare qith your own project. Nodify the sample project so it uses your CPUs as master and slave (change the HWConfig editor) and you should get comms between the 2 CPUs 313C-2DP. Then modify it to fit your data exchange requirements. http://support.automation.siemens.com/WW/view/en/6518822 Hope this helps, Daniel Chartier |
1/10/2011 1:51 PM | |
Joined: 4/24/2006 Last visit: 7/12/2024 Posts: 8711 Rating: (1166)
Dear Thanhnguyen, Perhaps these links might help: DP link between CPU 315-2DP (slave) and S7-400 (master) with STEP 7 V5.3 Master-slave connection between two CPUs in different projects Best regards, Wizard |
1/12/2011 10:56 AM | |
this is my image |
1/12/2011 10:59 AM | |
who know please help .my email is thanhnguyenvn89@gmail.com |
