8/30/2009 12:09 PM | |
Posts: 13 Rating: (0) |
Hi dear J-bell please help me abut connectig s7 200 and wincc.i have one plc s7 200 cpu222 and usb PPI cable(6ES7 901-3DB30-0XA0 and i have wincc explorer .do i need any hard or software and please tell me how to manage connection. thenk you Reza Attachmentuntitled.pdf (62 Downloads) |
8/31/2009 8:52 AM | |
Posts: 157 Rating: (10) |
Dear reza khorram, With the OPC server of S7-200 PC Access you can set up communication between the S7-200 and WinCC via OPC. You need first to install PC Access.. After saving your project inSTEP 7 MicroWIN, openPC Access.Within the PC Access, go to File>Import Symbols, and select your project. save you project in PC Access and go to WinCC Within WinCC; 1- Tag Manegment>add new driver>OPC.chn 2- OPC>OPC Groups>System Parameters, Then select the OPC you generate (\\<local>.....s7200OPCServer) Good Luck Regards, BilalD You can see the link bellow, |
