11/6/2017 4:16 PM | |
Joined: 4/28/2015 Last visit: 3/23/2024 Posts: 3345 Rating: (377)
Ok so there are many python libs to use Ethernet based communication
You have to install the required libraries on your IOT2000 using "pip3 install <package>" at first. I don't know if this AB PLC can communicate via ModbusTCP, but a simple TCP connection should be possible. Best regards! |
Not working for IOT2050 support anymore from March 1st, 2024. |
11/7/2017 2:31 PM | |
Hi, by default X1 of IOT2040 has the IP address 192.168.200.1 and X2 is set to dhcp. How to change the IP addresses you can have a look at the PDF document here. Best regards! |
3/13/2018 9:48 AM | |
Joined: 6/19/2017 Last visit: 4/26/2024 Posts: 7957 Rating: (162) |
New question published by c_conroy is split to a separate thread with the subject What library is needed to activate the I/Os?. Best regards |
3/16/2018 9:41 AM | |
New question published by Zay is split to a separate thread with the subject How to study IOT?. Best regards |
