10/9/2013 5:19 PM | |
Joined: 4/22/2010 Last visit: 12/13/2024 Posts: 5697 Rating: (715) |
Hello, Did you enable the data channel at the panel? Read more in : SIMATIC HMI HMI device OP 73micro, TP 177micro (WinCC flexible) Chapter 6.2 and chapter 7. Edit: oops your 6ES7972-0CB20-0XA0 is the wrong adapter, you can only use the serial/ppi cable or usb/ppi cable. Regards, Marcjan |
