6/18/2013 3:17 PM | |
Posts: 836 Rating:
Well, using only WinCC would also need to transfer the data by means of OPC... You can find a bunch of infos for OPC in the WinCC Help System (native WinCC, or PCS 7 WinCC, just go to index and type OPC) Check out this document for infos about perfomance of PCS 7 with OPC tags: http://support.automation.siemens.com/WW/view/en/59558350 |
