6/26/2024 11:38 AM | |
Joined: 8/3/2009 Last visit: 7/12/2024 Posts: 13284 Rating:
Hello The PT If you work with profisafe then something in the PLC Blocks seems not correct. check the appkicationexample: https://support.industry.siemens.com/cs/de/en/view/103497649 And you have to do the configuration of the safety type with every panel on every box. Bye Murof |
Last edited by: Murof at: 06/26/2024 11:39:02If this Information really helps, you could use the Rate function |
