12/2/2021 5:58 PM | |
Joined: 11/29/2021 Last visit: 6/26/2023 Posts: 5 Rating: (0) |
cpu 315-2dp is in run mode and cp 343-1 is in riun mode too, but showing sf red led. we i am going to get access of cp module from cpu it shows error "connection could not be establish" i am using pc adaptor to connect PG with cpu 315-2dp i replace the backplane connector but still problem not resolve. i have attached the screen shots of diagnostic buffer. please guide me. AttachmentDiagnostic (CPU & CP).zip (466 Downloads) |
Last edited by: Muhammad Jahangir at: 12/02/2021 18:00:41Last edited by: Muhammad Jahangir at: 12/02/2021 18:08:18 |
12/7/2021 8:35 AM | |
i want to access cpu through cp 343-1. when i connect my PG with cp and go online in hwconfig, cpu shows as non-active.
Attachmentethernet1.zip (440 Downloads) |
12/8/2021 9:20 AM | |
Joined: 4/28/2015 Last visit: 2/7/2024 Posts: 10533 Rating: (818)
Hello, really I think you did something not correct or idea what you do isn't right. Look to this similar topic: Download and connect to CPU with CP343-1 problem Try also download PDF to your CP343-1 version where some steps about correct cfg and services can be described, you can also download my prj attached in my link's Topic and look to that. |
