1/19/2009 10:16 PM | |
Posts: 32 Rating: (0) |
Hi, I need help about the connection modules TPA (6es7924-0ca10-0aa0). What is the terminals distribuition?, what is each screw? Thanks, Ronald Suriaga Autheman |
1/20/2009 7:29 AM | |
Joined: 9/27/2006 Last visit: 10/8/2024 Posts: 12285 Rating: (2685)
Hello Ronald; The following link will take you to the Simatic Top Connect portal, directly to the CAD libraryarea: https://www.automation.siemens.com/simatic_tc/html_76/library.htm There you should be able to select the technical drawing you need. Hope this helps, Daniel Chartier |
1/20/2009 8:32 PM | |
Thanks so much dchartier. |
