12/9/2013 8:03 AM | |
Joined: 4/24/2006 Last visit: 7/12/2024 Posts: 8711 Rating:
Hello MNielsen, What is the IP address of your PC? Best regards, Wizard |
12/9/2013 9:00 AM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating:
Hello,
Try with another ethernet cable. Pc can communicate with other devices? If still no communication with CPU, check local IP as mentioned above, if it's same as CPU you cant ping. If you still can't ping, IP of CPU must be wrong set or set back to default. You can try to reach the CPU with Primary Setup Tool Regards, Marcjan |
Problem solved? |
