6/3/2019 12:54 PM | |
Posts: 17 Rating: (0) |
Hello Siemens Forum! We are trying to make use of a SIMATIC IOT2040 by means of Port X1P1 via PuTTy. We have followed the instructions in SIMATIC_IOT2000_Setting_up_V2.1.1 manual up to table 3-4 item 3 but cannot proceed further. We also tried the tips in the below forums. We tried the dynamic via X2P1 via Wireshark, and still there was no response following Please note that when we are plugin the MicroUSB (X61) to any PC the PC does not find/recognize the IOT. How can we get this device to communicate ? Our next idea is to reset the IOT to factory settings, but that seems complicated. If we understand it correctly we have to create a bootable Linux SD Card , with Yocto and Poky!? But that all is something new to us where we arent really sure what to do. attached is a list what we already tried to fix that problem. Thankful for every help. Tom PS: A list what i already tried.. after thinking about all i think its not correct booting
Last edited by: RoundTriangle at: 06/03/2019 12:55:54Last edited by: RoundTriangle at: 06/03/2019 12:57:03Last edited by: RoundTriangle at: 06/03/2019 12:58:17 |
6/4/2019 7:12 AM | |
Hey tia! https://support.industry.siemens.com/cs/ww/en/view/109741799 |
6/4/2019 10:26 AM | |
Posts: 15 Rating: (1) |
Hi, hm, this hardware should work if you follow the description. Maybe there is something blocked at your PC... Here is an updated description. Did you have seen this? I would recommend to follow the mentioned description again and first just try a ping. This is the minimum that should work. AttachmentIOT2040_Tutorial-compactado.pdf (265 Downloads) |
Last edited by: Jen_Moderator at: 06/04/2019 12:50:48Added PDF as an attachment. |
6/4/2019 2:06 PM | |
Tried... didnt work. "Destination Host unreachable"... |
