2/21/2007 3:38 PM | |
Joined: 9/23/2005 Last visit: 8/13/2024 Posts: 4347 Rating: (1439) |
Hi, I can suggest you, that you use IO modules with diagnose. Then you can simule by swiths: Wire-break, short circuit, supply faults, etc. See in the ST70catalog (www.siemens.com/simatic/printmaterial), witch modules has witch diagnoses. You can also place the modules in the wonk slots, or, in ET200, you can also simule a loss of comunication by unplug the profibus cable. Battery fault can also easly be simulate. Thatare not software fault simulations, butare realistic fault simulations[;)]. |
Last edited by: Pegaia at: 2/21/2007 3:40 PMLast edited by: Pegaia at: 2/21/2007 3:39 PMDenilson Pegaia |
