4/9/2020 12:28 AM | |
Joined: 9/27/2006 Last visit: 7/14/2024 Posts: 12268 Rating: (2675) |
Hello skdahfgsal; This Application Example shows how to program a simple speed control for a V90 with a S7-300, using Profinet. https://support.industry.siemens.com/cs/us/en/view/109743898 Hope this helps, |
4/9/2020 6:30 PM | |
Hello skdahfgsal ; In that case, look at the DriveLib function library, it will work with S7-300 under TIA Portal v14 to v16. https://support.industry.siemens.com/cs/ww/en/view/109475044 The SINA_POS block should be able to control and position a V90 servo. Hope this helps, Daniel Chartier |
4/11/2020 10:08 PM | |
Joined: 10/10/2016 Last visit: 10/12/2023 Posts: 12 Rating: (0) |
I will look into this. |
4/22/2020 10:03 PM | |
I have gotten the communication working and I am able to move the drive from the plc, with your help, and the help of this video: https://www.youtube.com/watch?v=dT8zHc-phNI . The problem now is when I change the operating mode of the drive to operating mode 2(absolute positioning) it automatically turns off "enable Axis", when I manually turn on enable axis, the operating mode switches to mode 3. Any idea what could be causing this? thanks again. |
Last edited by: skdahfgsal at: 04/23/2020 01:27:52Last edited by: skdahfgsal at: 04/23/2020 01:28:08 |
4/23/2020 1:28 AM | |
never mind my issue was I had certain variable overlapping in memory. everything works now! thanks |
