6/28/2023 2:46 PM | |
Joined: 6/19/2020 Last visit: 11/21/2023 Posts: 1 Rating:
Kramja, I am experiencing a similar issue with TIA V18. Looking to convert from TP1900 Comfort PRO to Unified MTP2200. Have you had any success? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 06/29/2023 07:41:39New subject after splitting |
6/28/2023 8:59 PM | |
Joined: 4/26/2012 Last visit: 7/5/2024 Posts: 1547 Rating:
Hello, My usage comment, I used it in V16 (1.3) and V17 (2.1), from TP1200 to MTP1200 and then to Unified PC., without problems. Did you check the requirements in the documentation? LINK this is the content of the attached .txt? Remembering that it will not convert 100% of the project. -" I can't "manually" copy things from the old screens to the new. " This is not possible to do, you have to convert to reuse objects. good luck |
Last edited by: rdoliveira at: 06/28/2023 21:01:23edit Last edited by: rdoliveira at: 06/28/2023 21:03:50Last edited by: rdoliveira at: 06/28/2023 21:06:52Last edited by: rdoliveira at: 06/28/2023 21:12:04Last edited by: rdoliveira at: 06/28/2023 21:16:06Last edited by: rdoliveira at: 06/28/2023 21:17:31Last edited by: Jen_Moderator at: 06/29/2023 07:47:50Links optimized. "Always make a backup before and check the best time before testing." |
