12/15/2022 3:15 PM | |
Joined: 10/1/2018 Last visit: 8/23/2024 Posts: 74 Rating: (1) |
Hello all, I need to do some modifications in one HMI screen, whose visualization was programmed with Protool. But, since this software is obsolete and does not work in Windows 10, I need to convert it to WinCC flexible. The problem is that I tried to migrate the file .pdb by opening it with WinCC, according to migration manual, but it didn't work. Can anyone tell me how can I migrate to WinCC so I am able to work with it and load it to the HMI screen? Find attached the program with the Protool files stored in the folder TDOP. Thank you in advance Best regards ------------------------------------------------------------------------------------------ AttachmentPdn_pm4_20110927.zip (496 Downloads) |
Last edited by: Jen_Moderator at: 12/16/2022 08:06:06New subject after splitting |
12/15/2022 3:31 PM | |
Joined: 5/12/2006 Last visit: 10/11/2024 Posts: 22410 Rating: (3017) |
AttachmentPdn_pm4_20221215.001.zip (606 Downloads) |
12/15/2022 3:32 PM | |
AttachmentPdn_pm4_20221215.002.zip (666 Downloads) |
AttachmentPdn_pm4_20221215.003.zip (612 Downloads) |
12/15/2022 5:42 PM | |
as i say use 7-zip for extract |
12/16/2022 8:39 AM | |
Hello Cristoph, I unzipped the files you sent me with the software 7-zip but there are still some fauts when I do it and, when I try to open the files PROJECT_1.hmi or PROJECT_2.hmi with WinCC it appears an error message. All of this faults are showed in the pdf attached. It might be possible that some of the files are corrupt and that's why I can not open them? Thank you Best regards AttachmentFaults.pdf (509 Downloads) |
