3/21/2022 7:45 AM | |
Joined: 5/3/2017 Last visit: 5/21/2024 Posts: 673 Rating: (218) |
Hi mr Gun, if you create your own faceplate with copying the faceplate from a existing facaeplate you have to adapt some setting at the picture @PG_MyAPLFP.PDL
To see the objects you have to adapt the screen size and they can be behind other objects. You can find for more information how you create your own block icon or faceplate in the manual PCS 7 APL Style Guide at the section Creating project-specific blocks in conformance with APL. With regards |
3/21/2022 11:33 AM | |
Joined: 9/9/2014 Last visit: 8/28/2024 Posts: 75 Rating: (0) |
Hi, yes the step you mentioned are right. i just missed the last step of properties "BlockType" of the "ObjCollection" object. Previously i left still as "MotSpdCL" not "MotDual" Now it works as it should. Thanks |
