2/10/2020 8:00 AM | |
Joined: 1/28/2009 Last visit: 5/2/2024 Posts: 6838 Rating: (1359)
Hello, What do you think about using SFC20 and dynamic ANY Pointer.Check the following topic with a demo solution : Question about SFC20 BLKMOVI hope it helps, hdhosseini |
2/10/2020 8:56 AM | |
Joined: 2/5/2016 Last visit: 2/23/2024 Posts: 16 Rating: (0) |
Hi, I don't know which language you are using but maybe it would easier using SCL. I think this FAQ can help you. https://support.industry.siemens.com/cs/ww/en/view/21946854 |
Last edited by: and_si at: 02/10/2020 08:57:26Last edited by: and_si at: 02/10/2020 10:24:01Last edited by: and_si at: 02/10/2020 10:27:45Last edited by: Jen_Moderator at: 02/10/2020 12:23:02Optimized link. |
2/13/2020 4:17 PM | |
Joined: 6/24/2013 Last visit: 5/2/2024 Posts: 1595 Rating: (409)
Hi You can use the attached function DBDB_COPY which copies data from one DB to another and DBDB_CMP which compares areas in DB and returns indication if they are identical (i.e. recipe saved) 1. Create symbols for new FCs DBDB_CMP FC 100 FC 100 DBDB Compare 3. compile AWL file AttachmentDBDBCOPY.zip (222 Downloads) |
