5/25/2021 1:51 PM | |
hi, try to install the latest HSP for Step7 5.x: STEP 7 V5.x Hardware Support Packages (HSPs) for installing hardware updates in the Hardware ConfigurationMaybe there is also a SW required. Have a look to the installed SW on both PGs. Make sure that the SW is at least the version on the other PG. Better is to install the latest version on both PGs. hope this helps, regards, |
FCK WAR! |
5/26/2021 2:33 PM | |
Joined: 1/4/2007 Last visit: 8/8/2024 Posts: 1134 Rating:
Hello kuttysk, Regarding the Siwarex FTA module, you have to install the latest HSP. You can find the HSP for the Siwarex FTA module (and also a description how to install the HSP) here: https://support.industry.siemens.com/cs/nl/nl/view/79972902/en Best regards Siwarexi |
