12/28/2017 11:30 AM | |
Posts: 17 Rating: (0) |
I need to make a new image and I tried the "kas" method as it worked flawlessly last time I tried it. But now it fails consistently when running kas build meta-iot2000-example/kas.yml and the problem seems to be this: 2017-12-27 12:51:52 - INFO - Parsing recipes...WARNING: /home/perf/meta-iot2000/meta-intel-iot-middleware/recipes-devtools/parse-embedded-sdks/parse-embedded-sdks_1.0.1.bb: parse-embedded-sdks: LICENSE value "Parse License" has an invalid format - license names must be separated by the following characters to indicate the license selection: &|() Building meta-iot2000-bsp works fine! I have tried two hosts, one Virtualbox on windows 10 and a native ubuntu on a laptop. All running ubuntu 1604. Any hints? Regards -Per ------------------------------------------------------------------------------------------ |
