9/17/2012 10:41 AM | |
Posts: 11 Rating:
Dear Zangetsu, I found some problem like your post. I have tried and adjusted but not success. Could you check my project as attached , and then recommend. Thanks in advance.. Phayalek AttachmentValveFB.zip (60 Downloads) |
Last edited by: O_Moderator at: 9/18/2012 10:56 AMnew subject after splitting from /tf/WW/en/Posts/62977#top |
9/25/2012 5:41 PM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating:
Hello, You used Edge detection in your SBR: Edge evaluation in the subprogram you can use this In STEP 7 Micro/WIN, how can you evaluate unlimited rising and falling edges in main programs or subprogram? And take care that all variables that need memory are off the type in/out not temp. What should you watch out for when using the local variable types OUT and TEMP in subprograms? regards, Marcjan |
Last edited by: Marcjan at: 9/25/2012 5:54 PMLast edited by: Marcjan at: 9/25/2012 5:45 PMLast edited by: Marcjan at: 9/25/2012 5:45 PMProblem solved? |
