4/21/2012 12:13 PM | |
Posts: 621 Rating:
Hi Dear valueable experts and my friends Here is im trying to reset the count see the picture MD26 is my counter value and L# 30 is preset value i compare the both value after crossed preset value MD26 get reset. but it is keep on increse the count.check the program snap and let me know where i done the mistake warm regards algudkar Attachmentpictu.zip (114 Downloads) |
4/21/2012 1:47 PM | |
Joined: 1/28/2009 Last visit: 9/10/2024 Posts: 6849 Rating:
Dear friends, #F_UP would be the auxiliary memory to positive edge. "algudkar",Please upload the whole code or the FB to provide you a solution.This would be done by definig a reset (binary input) and using this input to jump all calculation area and reset every thing. Hope this helps. Best regards, Hamid Hosseini |
4/21/2012 2:13 PM | |
Posts: 621 Rating:
Hi hdhosseini thank you for your reply.and i attached(Upload) the program code regards algudkar AttachmentCOUNTER.zip (93 Downloads) |
4/21/2012 2:16 PM | |
Posts: 621 Rating:
Hi niranjan thank you for the prompt reply........... regards algudkar |
4/21/2012 2:36 PM | |
Hello , See the attachment, ask for clarification if ncessary. Best regards, Hamid Hosseini AttachmentZAHLEN.pdf (128 Downloads) |
4/25/2012 6:40 AM | |
Posts: 691 Rating:
Better change the Equal Function than Greater/Equal . If I am not wrong with your application
AttachmentFB2.pdf (117 Downloads) |
4/28/2012 5:55 PM | |
Posts: 621 Rating:
Hi hdhosseini last topic i was discussed with you regarding the counter. as per your attachment i write the program but the block will not work. just check out the attached same regards algudkar AttachmentFB.zip (74 Downloads) |
4/30/2012 5:40 PM | |
Hello again, I found the project I developed for your case.As I remember it was working at the moment,Please test and update the result here. Best regards, Hamid Hosseini Attachmenthd_counter.zip (120 Downloads) |
