6/4/2020 9:23 AM | |
Joined: 8/3/2009 Last visit: 4/30/2024 Posts: 12869 Rating: (1642) |
Hello Le_Taffy@ perhaps you check your configuration steps with the Example in this FAQ: https://support.industry.siemens.com/cs/de/en/view/58638283 Bye Murof |
6/26/2020 5:15 PM | |
Posts: 31 Rating: (0) |
Thank you very much for you reply. However, i am working on Tia portal V14 and he example is done with the tia portal V13 and V15. |
