10/5/2022 8:35 AM | |
Joined: 8/3/2009 Last visit: 4/26/2024 Posts: 12869 Rating: (1641) |
Hello C-3PO you could check in the current application example: https://support.industry.siemens.com/cs/de/en/view/58638283 Bye Murof |
10/5/2022 10:41 AM | |
Joined: 5/30/2014 Last visit: 4/16/2024 Posts: 140 Rating: (17) |
Hi Murof, I have already checked that example and no changes. I tried this diagnostics (How do you read out advanced diagnostics data from the CP 1242-7 GPRS V2?) and it shows error 3= WAITING_PIN. But I configured and checked PIN several time, checked on mobile and it works?! Now I suspect that problem is with PIN, or maybe with APN settings? |
Last edited by: C-3PO at: 10/05/2022 10:49:49Last edited by: C-3PO at: 10/10/2022 14:31:21If you find my contribution helpful please RATE it :)) |
