6/11/2012 9:59 AM | |
Joined: 9/28/2005 Last visit: 7/10/2024 Posts: 2957 Rating: (242)
I think its good idea to review configuration of ethernet module. Please thake this FAQ as reference How do you configure communication between WinCC flexible Runtime or a Windows-based operator panel and an S7-200 (CP 243-1) via Ethernet? If you have problems with download I don't believe its a panel's fault. |
Best regards, |
6/11/2012 5:13 PM | |
Joined: 5/4/2009 Last visit: 5/28/2024 Posts: 914 Rating: (40) |
By the way the "Ether0_CTRL" showing no error, please see attached. Regards.
Aim Higher |
6/12/2012 8:59 AM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating: (714)
Hello, Hope the attached document (cant read most off it) makes things clear about TSAP and cable, i think you need crosscable. Regards, Marcjan AttachmentPLC_connection_guide.pdf (229 Downloads) |
Problem solved? |
