11/3/2009 8:24 AM | |
Posts: 382 Rating:
Dear therfro, It could be. What is yourversion of theSimatic Net PC Software? It may not be compatible with XP SP3 [see attach]. CP5613 is a older profibus card. The new one is CP5613 A2. These links might be helpful to you. CP5613 CP5613 A2 I ever encountered this error message before. It was because of our bad profibus shielding done with the connector that connected to the CP5613. After we did a proper shielding connection, the problem was solved. I am not sure whether this could be your case as you said the plant run without any problem for 4 years. Hope this helps! with regards, how come AttachmentSTEP7_ALM_WinCC And Other More Compatibility Chart 2009.pdf (276 Downloads) |
