5/14/2009 8:58 AM | |
Posts: 196 Rating:
Hi Haroon For the PN cpu’s you should use open communication wizardhttp://support.automation.siemens.com/WW/view/en/25209116 Her you can read all about how to set the communication and how to use the function blocks from the standard library, I have use the wizard and it works fine. As you get in to the communication for the PN cpu’s the have more advantage the old cpu’s e.g. you can change ip address to the partner without downloading new netpro configuration. |
