11/29/2005 2:08 PM | |
Joined: 10/5/2005 Last visit: 4/9/2024 Posts: 63 Rating:
Hi, there is only a modbus slave from Siemens. An example you will find on: https://www2.automation.siemens.com/microset/html_76/support/tipps/tt-kommunizieren.htm Click on Tip 41... Or you buy a official product. It's called "Instruction Library" https://mall.automation.siemens.com/DE/guest/index.asp?aktprim=0&nodeid=10009333&lang=en&foldersopen=-1-10906-1070-1071-1072-1073-1074-1121-1123- But it's also a slave only... Last but not least: There is an modem module EM241. This one is able to work as a master or as a slave. Look to: https://mall.automation.siemens.com/DE/guest/index.asp?aktprim=0&nodeID=10007503&lang=en&foldersopen=-1-10906-1070-1071-1072-1073-1074-1121-1123-1106-1107-&jumpto=1107 Thats all I know about modbus. Regards! Mausus |
3/7/2006 6:35 PM | |
Posts: 62 Rating:
I checked the program and it's okay to send per the notes provided by Siemens. Have at it and good luck. Drop me a line if there's any questions. Best Regards, Thumper AttachmentModbus_master.zip (567 Downloads) |
