10/17/2011 8:08 PM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating:
Hello, Have a look at the tips and tricks : http://support.automation.siemens.com/WW/view/en/1232912 Tip 28. Or http://support.automation.siemens.com/WW/view/en/19539448 It's possible. Also have a little search on the forum, more threads about this issue. Regards, Marcjan |
Last edited by: Marcjan at: 10/17/2011 8:14 PMLast edited by: Marcjan at: 10/17/2011 8:13 PMProblem solved? |
10/17/2011 8:11 PM | |
Joined: 9/27/2006 Last visit: 7/14/2024 Posts: 12268 Rating:
Hello Tomy; There are many references in the MM430 Parameter List manual for USS communications: http://support.automation.siemens.com/WW/view/en/24479411 They should give you details of the required connection arameters. Hope this helps, Daniel Chartier |
