4/5/2024 7:10 AM | |
Joined: 1/21/2013 Last visit: 9/12/2024 Posts: 3093 Rating:
Hi Atzeni, Instead of placing a PLC as a dummy in the TIA Portal project, you should use Inter Project Engineering (IPE). This allows you to import any PLC content that may be of interest to the HMI. For example, you can access tags, data blocks, and alarms, but not functions or function blocks. See the application example. Kind regards |
