10/17/2008 10:32 AM | |
Posts: 2 Rating: (0) |
Hi, i'm newbie on the profibus. Could you help me guys to solve my problem. I'm using CPu 313C-2DP as slave, i followed the instruction and load to plc but PLC give error: "STOP caused by PG stop operation or by SFB 20" Kindly show me some sample program to send from DB2.DBD to profibus master. Thank you |
Last edited by: O_Moderator at: 12/14/2010 11:26 AMlink edited Last edited by: CS Moderator at: 10/19/2008 11:04 PMLast edited by: CS Moderator at: 10/19/2008 11:04 PMnew subject after splitting referred text inserted |
10/18/2008 5:57 AM | |
Posts: 26 Rating: (2) |
hI This is regarding to your advice/suggestion to Mr Ivan.Can u Plz brief about the cyclic request from Master. Because with Same DeltaV as Master we are able to communicate with other Profibus slaveS like CP342-5 , dp-dp COUPLER,EM 277 Modules. Also plz. find enclosed the zip file for your kind reference. AttachmentProfidp_.zip (221 Downloads) |
