5/27/2010 3:44 PM | |||||
Joined: 9/27/2006 Last visit: 7/14/2024 Posts: 12268 Rating: (2675) |
Hello Ton; The CP 343-1 Lean can act as a Profinet I/O device, not as a controller:
https://www.automation.siemens.com/net-static/Quickstart2009/quickstart012003/ftp/profinet/CP343-1_LEAN/QSCD06_CP3431Adv_CP3431Lean_IODevice_e.pdf Hope this helps, Daniel Chartier |
5/28/2010 9:51 AM | |
Joined: 4/20/2007 Last visit: 5/27/2024 Posts: 724 Rating: (42) |
Hi! Thank you! I will order the normal 343-1 module. Thanks for all the help! |
5/28/2010 10:10 AM | |
Joined: 12/9/2009 Last visit: 4/18/2024 Posts: 156 Rating: (11) |
Hello, the current CP343-1 Standard module is the CP343-1EX30 (6ES7 343-1EX30-0XE0). Here ist the manual: http://support.automation.siemens.com/WW/view/en/24485272 Here is a sample program how you configure a CP343-1 as PROFINET IO controller: http://support.automation.siemens.com/WW/view/en/26558253 Good Luck |
5/28/2010 12:33 PM | |
Hey, Thats the one I ordered! Thanks! |
