9/25/2008 9:10 AM | |
Joined: 9/27/2006 Last visit: 8/27/2024 Posts: 12279 Rating:
Hello maarte; The following application from Siemens support gives a vey good explanation on how to connect a PN/DP CPU wwith a CP 443-1 using "Open TCP/IP". You will also find a pdf documentation file, and a sample project you can use to adapt your own project http://support.automation.siemens.com/WW/view/en/25209116 Hope this helps, Daniel Chartier |
9/25/2008 10:29 AM | |
Posts: 3 Rating:
yes, I found this topic but it is not help me.... I know how to generete communication data in communication wizzard and i have this db. I use FB in cpu 315-2 PN/DB but i don't know which FB or FC use in CPU 315-2 DP with CP.... AG_SEND and AG_RCV are not correct block in this situation.... In attachment is my project... AttachmentEthernet.zip (709 Downloads) |
9/25/2008 12:42 PM | |
Posts: 162 Rating:
This is a good tip, thank you. Best regards FrankW |
9/29/2008 7:57 AM | |
Posts: 3 Rating:
Hi! I did it. I used S7 Connection in net pro and FB14 and F15 in my program. Thanks.... |
