11/4/2015 9:23 AM | |
Posts: 567 Rating: (107) |
Hi, I think your CPU is not released for PCS 7 that's why you can't select it in the wizard.
Last edited by: The Helping Hand at: 11/5/2015 10:19:44 AMMade the link clickable |
11/4/2015 9:29 AM | |
Posts: 163 Rating: (2) |
Thanks you for your response. I made an edit to my original post. I believe that I could access the features of PCS 7 using 413-1 right? Kind Regards, |
11/4/2015 9:47 AM | |
You can try it. But I think there is a reason why this CPU is not in the PCS 7 profil. |
11/4/2015 5:23 PM | |
Joined: 10/26/2011 Last visit: 10/1/2024 Posts: 762 Rating: (191)
Set in the Hardware Manager the "Profil" to "Standard", then you see under "SIMATIC 400" the 413 CPU. If the normal PCS 7 Library do not work, you can use the Industry Library. In the Industry Library (made for 300 CPU integration) you have also Faceplates and Icons in APL style.
11/4/2015 7:53 PM | |
Thanks for replying. This is what I have been doing all day. What can you say about it? Regards, |
And |
11/4/2015 7:54 PM | |
And |
11/5/2015 7:50 AM | |
Hi, can you describe exactly the Problem. I can't see it in the screenshots.
