6/19/2012 12:37 PM | |
Joined: 7/2/2008 Last visit: 5/23/2024 Posts: 928 Rating: (306)
Hellopooneh, It's very hard to find the manual. Maybe if someone has manual collection of 2004 can help you. Anyhow, the Synch. module 6ES79601-1AA04-0XA0 and FO patch cable 6ES7960-1AA04-5AA0 were released for the CPU in question 6ES7414-4HJ04-0AB0. Please checkEnd of Production for Previous S7-400H CPUs. I hope you have the synch. modules in stock because byOctober 2012you won't be able to buy it and you will have to completely switch to the newV6 CPUswith the new Synch. modules (6ES7 960-1AA06-0XA0). Best regards, H-H
6/19/2012 12:47 PM | |
Joined: 9/27/2006 Last visit: 5/25/2024 Posts: 12257 Rating: (2668)
Hello pooneh; Have a look at the Product link for your CPU: http://support.automation.siemens.com/WW/view/en/17958040 You could have located it yourself had you used the Search box on the right side of this page... Notice first that it is described as an H-CPU, so yes it will accept synchronisation modules (with the fiber optic connection) for redundnacy. Notice next that it is in cancellation phase. SoI hope you have 2 of them, along with the sybchronisation modules, if you want to setup a redundant H-system. This manual might be of service for your application: SIMATIC Fault-tolerant systems S7-400H It discusses amongst other things the hardware requirements for a H-system. Hope this helps, Daniel Chartier |
6/19/2012 1:03 PM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating: (713)
Hello, And to complete the information, i found older manual with 6ES7 414-4HJ04-0AB0 in it. See attachment. Regards, Marcjan Attachmentstep 7 - fault-tolerant systems.pdf (74 Downloads) |
Problem solved? |
6/20/2012 9:12 AM | |
Posts: 11 Rating: (0) |
ThanK you very much for information |
