6/12/2016 9:47 AM | |
Joined: 5/28/2008 Last visit: 7/16/2024 Posts: 4511 Rating:
Hello. PCS7 V7.0 is older than the mentioned CPU. PCS7 V7.0 released from 2006 if I remember well while CPU (6ES7 414-5HM06-0AB0) released on 4/5/2012. You can check the modules released for PCS7 V7.0 from here: You can found the mentioned CPU starting from PCS7 V8.0. Please check the released modules for all PCS7 versions from the following link: Which modules and their firmware versions are released for PCS 7 and how can you update them? Hope this helps. |
Ayman Elotaify |
